clutch specs
I will be doing the clutch on my car this week, and i need to know the specs for installing it. I need the torque specs so if anyone can help me out, i would greatly appriciate it.
it's a '97 legacy awd wagon w/ a 2.2...anything else u need to know?
I don't know the specific torque specs. Just don't overtighten the pressure plate bolts. Other then that, every thing else is pretty straight forward if you've done a clutch job before.
i just did my clutch on my 97 subaru outback. its a 2.5l but i used a haynes manual and if i remember the flywheel was 65 ft lbs and the clutch plate was 132 IN lbs. so dived that by 12 if you don't have an inch lb torque wrench. they may be different on a 2.2 but i can't imagine that much..
