need help with 2.5 sti shortblock
I put a 2.5 sti short block in a legacy GT2.5, used sti gaskets, but stock heads.
I'm getting ok power (comparable to what you'd expect from a healthy ej22),
low compression, & HORRIBLE mileage) the engine runs PERFECT, so I'm leery about major changes, but need to figure this out.
I drive over 11,000 ft twice a day, so the gas is killing me.
any suggestions?
I've got a weaponR intake & lightened flywheel, other than that no extras.
Well the good news is it might run forever. I believe the 2.5 STI is turbo isn't it? In this case you have about the same compression ratio as a Briggs and Stratton. I thought of doing this myself to make the ultimate tough 2.5. The bad news is that you would lose power and gas mileage most likely. It really should be just a bit better that a good 2.2 but will be running when you are dead.
it went down to 8.5 because of the increase in thickness to sti gaskets (I think) obviously at my altitude, a loss of compression was the last thing that I wanted, but the shop that did the work didn't mention that I would lose t with this setup (I guess it should have been obvious, but it didn't cross either of our minds)
would 1/2 lb loss cause this huge change in efficiency?
I meant was the STI shortblock meant to be turbo? It sounds to me that you have exactly what you ordered.
If you want to drive to CA I will be happy to trade engines with you. According to the STI I just looked up it should be a shortblock for a 300 hp intercooled turbo. If you put that together with no turbo and a stock set of 2.5 heads waht you have is exactly the result. Congratulations! You have just built an excellent non-performance motor.
If you found the right set of 2.2 heads you might be able to get usable horsepower for your altitude. I suggest you check with NASIOC to see if anyone knows which heads have less ccs in the chamber.
