Power Steering pump seal kit?
I've read several threads on replacing the power steering pump seal. The Subaru dealership however says it doesn't exist and that I would have to by a whole pump. I asked them for the parts explosion but I still don't see it anywhere. Does anyone know the part number?
dylan,
your best bet is to pull the power steering reservoir off and install a new o-ring. i believe between the reservoir and the pump there is an oring that leaks all the time. from what i've heard that oring is the major cause of power steering pump leakage and it's super easy to do.
Thanks Gary, I was sure if the front seal where the pump axle to pulley meets. That seal/bearing has a circlip holding it in. But I could change the O-ring for sure under the resevoir.
Thanks
