Spent some time in the garage...(PICS!!!)
I was home for a couple days before school starts and I was cleaning out the mess in the car. Well the wire running for my aux input from my headunit to my nano and xm radio was kinda of an eye sore. along with the xm sat antenna not actually run properly, the wires were everywhere!!
i just wanted to post some pics of the finished install (headunit connected with 3.5mm plug and sat antenna run are the two cables you see.
I wanted to run a invertor or some sort of power to the center console location, but didnt seem a priority.
enojy
BELOW: inside the center console.... note the great craftsmanship on the wire outlet, rubber outlet with wire managment
BELOW: the nano and the xm radio fit fine with plenty of room
BELOW: close up of drill hole needed, used a large rubber o-ring to make the egdes wire safe, and then tied a zip tie to make sure the wire only comes out but so far. after that hot glue guned the rubber to the console from the outside.
BELOW: carpet, shows the wires coming together
BELOW: here is a close up, sorry for the blurry, on the otherside of the center console.
BELOW: headunit, its fairly old, had it since high school, which was about 4 or so years ago... but i wish i had rear aux inputs :(
BELOW: pics of xm antenna, i love the small sleak antenna, the wire is a very small guage so it was easy to tuck into anyplace i needed to...
and more
BELOW: just another view of the install
i just hope that it lasts and works for a while, and maybe inspire someone out there to organize their setup...
-ali
