January 21, 200620 yr Hey, EA-82, F.I., none Turbo. You know those 1/4 inch heater hoses that run to the carb and out the back the dealer wants $14. apiece.... so.... I used 1/4" fuel line as one split, .... the back one is a sharp 90.deg bend... seems to be o.k. but not as tubular as the factory formed... Any problems with using the fuel line rather then the factory formed 1/4" hose?
January 21, 200620 yr The fuel line may not designed for the higher temperatures that the coolant is at. it should be ok, but i'd keep an eye on it, just in case.
