2WD to 4WD conversion
Is it possible to convert a 2WD wagon to a 4WD without too much modification? Most likely a newer model, about a 95 maybe...
Short answer - yes. It's largely a bolt on. You need basically everything aft of the engine. A donor car is recommended (wrecked is fine).
so you want to convert a legacy? or impreza? everything after 96 was AWD. if your talking about an EA82 then the newest you will find is like 92ish.
if your talking EA82 then i have everything you will need.
PM me if interested.
Are you getting a 2WD Sube free or really cheap? Because otherwise it'd be easier to just buy a 4WD from a Board member. Lots of them up your way.
