Monte Posted January 29, 2006 Share Posted January 29, 2006 There's a micro switch on the driver side of the heater, near the throttle pedal, anyone know what it hooks up to? I just pulled the dash and heater because of a mouse nest inside the heater below the heater core, the car was sitting for a few years. Dash and heater are back in the car, but I can't remember if this switch was hooked up to anything and I can't find it in Haynes or Chilton wiring diagrams. 2 wires, white -| connector. Maybe something for A/C, which this car doesn't have. Thanks, Monte Link to comment Share on other sites More sharing options...
Skip Posted January 29, 2006 Share Posted January 29, 2006 yes it is for the AC control I rewire mine to a small rocker on the dash beside the blower speed knob Having AC on your feet is kewl in the summer Hope this helps Link to comment Share on other sites More sharing options...
Monte Posted January 29, 2006 Author Share Posted January 29, 2006 Thanks, Monte Link to comment Share on other sites More sharing options...
Skip Posted January 29, 2006 Share Posted January 29, 2006 You're welcome The wiring harness connector for the switch is in the center console same side as the switch, close to the front of the panel very near the antenna connector Link to comment Share on other sites More sharing options...
Monte Posted January 29, 2006 Author Share Posted January 29, 2006 You're welcome The wiring harness connector for the switch is in the center console same side as the switch, close to the front of the panel very near the antenna connector I couldn't find anything in the harness to hook up to the switch. I asked about it incase I buried the harness connection when I reinstalled the dash. The car doesn't have A/C, so there shouldn't be anything to hook up, right? If there is, it's buried/caught on something and I need to dig around for it. Next time I'll tape and mark wires as I disconnect them. :-\ Monte Link to comment Share on other sites More sharing options...
Skip Posted January 29, 2006 Share Posted January 29, 2006 "The car doesn't have A/C, so there shouldn't be anything to hook up, right?" Right you are, Sir Monte Link to comment Share on other sites More sharing options...
Monte Posted January 29, 2006 Author Share Posted January 29, 2006 "The car doesn't have A/C, so there shouldn't be anything to hook up, right?" Right you are, Sir Monte Thanks. Later, Monte Link to comment Share on other sites More sharing options...
