TurboPropAirman Posted January 31, 2006 Share Posted January 31, 2006 My 99' Legacy has two problems I am unable to fix, and I was wondering if anyone could help. My check engine light, and at oil temp light are flashing, when I put my car into drive or reverse its very hard to get going (I have to shift to neutral rev it up a bit, and shift back into drive) in order to get going. Sometimes during this time my engine will make a popping noise. When I scanned it using the OBDII I recieved the codes MAF/VAF Circuit low input --- I cleaned the old sensor (didnt work) replaced the sensor(no affect), and replaced the ECU (nothing). I think it has to do with the wires but I dont know what to look for on the multi-meter. Cylinder 2 Misfire detected --- I replaced the Ignitor coil, but I believe this is a secondary problem, and may be corrected with a new coil once the MAF sensor is fixed. Any ideas on what to do or how to fix this problem will be greatly appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted January 31, 2006 Share Posted January 31, 2006 First thing I'd do is check the resistance on the wiring going to the MAF sensor and see if you have a short or wire that has a high resistance. If you've replaced the sensor and ECU, I don't see what else it could be. Have you gone to the dealer to pull the TCU codes? Or can you pull them yourself with the scan tool? Quote Link to comment Share on other sites More sharing options...
TurboPropAirman Posted January 31, 2006 Author Share Posted January 31, 2006 I have not pulled the TCU codes, is there anyone other than the dealer that can do it??? I dont want to pay an arm and a leg to have them do it. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted February 1, 2006 Share Posted February 1, 2006 There may be a procedure to pull the TCU codes yourself, but I'm not sure what it is for the newer cars. I'd suggest searching the board and see what you come up with. Quote Link to comment Share on other sites More sharing options...
