N8NQU Posted February 8, 2006 Share Posted February 8, 2006 my pasengers front wndow wont go down,i have the motor out and i will only go one way,i have tried 3 motors and 3 switches and all do the same thing ( ONE WAY ).can i get some input which way i should start looking,i need to get it fixed because i use it to deliver papers.thank you.Bill p.s. the other 3 windows work fine. after looking and tracing wires with the help of the FSM i got the problem fixed. i found a conector not pluged in all the way at the drivers side kick panel.thanks to all replys,Bill Quote Link to comment Share on other sites More sharing options...
Subarian Posted February 8, 2006 Share Posted February 8, 2006 Have you checked the voltage at the connector that hooks on to the electric motor? If you've tried three motors and three switches, it sounds like a bad wire or connector. Quote Link to comment Share on other sites More sharing options...
N8NQU Posted February 8, 2006 Author Share Posted February 8, 2006 i got voltage on switch,when i presss up and down.it's got me wondering??? Have you checked the voltage at the connector that hooks on to the electric motor? If you've tried three motors and three switches, it sounds like a bad wire or connector. Quote Link to comment Share on other sites More sharing options...
azsubaru Posted February 8, 2006 Share Posted February 8, 2006 Seems like the voltage would have to reverse polarity to go in the opposite direction. In other words, if the meter read positive12 Volts when moving, it should read negative 12 Volts when you push the switch into the other position. Does that happen? Also, sounds like you're reading at the switch. That checks out the switch but you need to check voltage at the motor to make sure it's getting over there. Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted February 8, 2006 Share Posted February 8, 2006 yea, I believe AZ is right; to test the motor, just jump 12v to it. To make it change directions, just switch the polarity of the wires going to it. as to the underlying issue with the switch... I'm not sure there... Quote Link to comment Share on other sites More sharing options...
Subaru Jim Maple Ridge Posted February 8, 2006 Share Posted February 8, 2006 Just a guess, but I think all the power (and grounding) in those harnesses depend upon the switch on the left front door, regardless of which window you are playing with. Quote Link to comment Share on other sites More sharing options...
N8NQU Posted February 10, 2006 Author Share Posted February 10, 2006 It's fixed,read original thread.thanks,Bill http://www.ultimatesubaru.org/forum/images/smilies/dbanana.gif http://www.ultimatesubaru.org/forum/images/smilies/dbanana.gif Quote Link to comment Share on other sites More sharing options...
