February 11, 200620 yr more info. on conv of toyo 6 lug wheels to sube .their seems to be a diff between 4x4 and 2 whl drive rims. which ones????? great site keep up the good work.
February 11, 200620 yr Subaru wheels use a 4X140 lug pattern, whether 2 or 4 wheel drive. You have two options to convert to 6 lug wheels: You can redrill the wheels to fit the 4 lugs on the subaru, or you can redrill the hubs to fit the wheels.
February 11, 200620 yr Author thanks for the info, but i was given a set of 6 lug toyo rims that would not clear the calipers on the front of my toyo. just wondering. also is it correct that the drum drill size is 19mm??? thank s for all the help.
