February 13, 200620 yr I've searched the archives for info on code reading and here's what I've learned so far: -- the '90-'94 is OBDI -- the '96+ is OBDII -- the '95 is 'not quite either' and hence code readers for one or the other don't work on the '95. Is this correct? And, if so, how then does one pull and clear codes on the '95? Thanks in advance! Rob Kuhlman
February 13, 200620 yr OBDII was mandated on all US cars starting in '96. Some manufacturers, including Subaru, started using it earlier. My '95 Legacy is fully OBDII compliant to the best of my knowledge. Code reader works just fine on it.
February 13, 200620 yr OBDII was mandated on all US cars starting in '96. Some manufacturers, including Subaru, started using it earlier. My '95 Legacy is fully OBDII compliant to the best of my knowledge. Code reader works just fine on it. Ditto what Olnick said. You should be able to plug an OBD2 reader into it.
