elmwood22 Posted February 18, 2006 Share Posted February 18, 2006 My 99 obw starts fine when cold, however, when cold, like most engines, idles at about 1800-2000 rpms, until warm or when I push the gas pedal to lower the idle, this is normal. When I perform this procedure my engine will slightly cut-out, which is not normal. But for some reason it does this when cold, not when warm. I have also noticed that when I push the gas pedal down quickly, warm or cold, the engine hesitates slightly, before it can recover. Performing these procedures has never killed the engine, however I cannot stop wondering what the problem may be, if there is one. Any ideas? I have changed the plugs- and this did nothing. I would like to start simple. The vehicle has 80k. Thanks suby fanatics Link to comment Share on other sites More sharing options...
Legacy777 Posted February 19, 2006 Share Posted February 19, 2006 My n/a motor did that occasionally too. It might be the coolant temp sensor, but if it's similar to what I had, it's probably not. If I let the car idle/warm up for a few minutes I did not have the problem. Link to comment Share on other sites More sharing options...
