March 9, 200620 yr Hi, Ive come here for some information. i have a '92 loyale and the check enging light has been coming on and off during travle for about 4 months. eg. i turn on the car, and the light will some times be on, other times it will not be. and i drive for a bit then during travel it will turn off or on and will some times continue doing this every 5-25 mins or so. and recently i found two loose wiring harnesses inder the hood (near the wiper moter) and connected them, one was a green harness, and the other white. and then while driving after my light was on for roughly 5 mins or so, the light began to blink, once every second. my friend told me i connected the harnesses to diagnose the light. and i am wondering what the code is for the light blinking once a second. * note* when the light turns off/on i notice no change in performance in the car. thanks for any help!!!
March 9, 200620 yr those loose wires were the problem. They are supposed to be unhooked. The green connector is a test mode and kicks your fuel pump and and off at 1/2 sec intervals. The white connector is a read mode connector which is used for pulling codes off the ECU The flashing of the CEL is a OK. they do that if everythign checks out on them
