March 22, 200620 yr My problem is that with engine at idle speed(850-900 rpm), if I press brake pedal, RPM falling down around 6-700 rpm even if engine is warmed up.Could be vacum leack??Or what...?? Thanks 1 million.
March 22, 200620 yr It could be a vacuum leak with the brake boost cylinder or a crappy electrical connection with your brake lights that causes too much of a draw on your alternator. (I've had the second one happen) P.S. A year and model will help a lot. -Justin
March 22, 200620 yr Author It could be a vacuum leak with the brake boost cylinder or a crappy electrical connection with your brake lights that causes too much of a draw on your alternator. (I've had the second one happen) P.S. A year and model will help a lot. -Justin 1986, Leone, Sedan, EA82, 1.8GL, Carb, 4WD. Thanks.
