Subaru in the Rainfroest Posted April 4, 2006 Share Posted April 4, 2006 my clutch is slipping a little and i want to adjust it. i know where the are to be made at. but which way to turn the nuts. i may be wring about the clutch slpping to. could just be the moter because of the oil. lostintherainforest Quote Link to comment Share on other sites More sharing options...
Subaru Jim Maple Ridge Posted April 4, 2006 Share Posted April 4, 2006 You compensate for wear by adjusting the nuts towards the front of the car. You should set the pedal height as low as you are comfortable with. If it still slips, you need to replace the clutch. Quote Link to comment Share on other sites More sharing options...
Subarian Posted April 4, 2006 Share Posted April 4, 2006 You need to leave at least 1 mm of free play, or you will prematurely wear out the clutch and/or throwout bearing. Quote Link to comment Share on other sites More sharing options...
