April 13, 200620 yr it;s the passanger front only , all other work, the switch at the drivers side does not work or the switch at the door
April 13, 200620 yr Probably a burned out motor. Pull the plug from the motor, and use a multitester on the contacts while pressing the switches. If you get power for both up and down (you'll have to move the probes for the different directions), the motor is bad. If you aren't getting power for one or both directions, it's a switch or wiring problem.
April 13, 200620 yr Author got it , this is 86 subaru 's wife , did it myself found extra passanger side switch in a box full of extra window switches , he is taking a extra run tonight ,soooooooo had to fix it myself , chance of rain thanks
