April 20, 200619 yr My 4wd button rattles and makes a bunch of racket on the freeway in my justy, and I'm thinking of taking the shift knob off and running the wire for the 4x4 switch into a switch in the dash somewhere. I know there is a screw on the front of the knob, but what are the little holes in the side? how do I get it off?? Thanks!
April 21, 200619 yr Sweet Justy! I believe there is a hollow tube in the middle of the shift knob that you have to push out (really hard to do) to let go of the red button.
April 21, 200619 yr Author Thanks! For the help and compliment. Ditching the gold decal and using a stencil to spray white tonight. Sweet Justy! I believe there is a hollow tube in the middle of the shift knob that you have to push out (really hard to do) to let go of the red button.
April 26, 200619 yr Author Okay, I see the little rod that I need to "push" out, but I cant seem to get it to budge. Any tips or ideas?? Thanks again! Dylan
April 26, 200619 yr Its a roll pin, like the axles, i have the button, but on the DL/Loyale body, i used a 20 cent mexican coin and it hasn't rattled since, that was over 4 years ago. cheaper and easier, a nickle should fit nicely.
April 26, 200619 yr Author i had pennies and cardboard wedged in there, but it still rattled around (Although it did help a little). But what is a roll pin?? Is it threaded or something? Thanks, Dylan Its a roll pin, like the axles, i have the button, but on the DL/Loyale body, i used a 20 cent mexican coin and it hasn't rattled since, that was over 4 years ago. cheaper and easier, a nickle should fit nicely.
