April 23, 200619 yr my 1989 justy has lost ignition spark. I can't find a manual on the subject so here I am. I recently (fixed) a catalytic converter problem, the car ran fine for 5 minutes then nothing. I believe the secondary ignition is ok...
April 23, 200619 yr Hi, check the basic,s first...make sure all fuse,s are in order and good..then go round and check all your connecters, then double check where you carried out the work on your cat..and see if you mistakenly unpluged or bumped any wiring..its the way to go first before thinking about testing components....goodluck
