Hello.................Question is for a 98 Impreza OBS.
Does anyone know or can identify which screw does what for headlamp
aiming adjustments? Two on each of the headlights.
Just want to adjust the up /down ....not side to side.
Thank You very much for all answers!!!!
That's not something a lot of us do at home. I have only done it in a shop with a headlight target chart. If you must do it at home face a wall with your car and turn on the lights. Mark where the car is now and mark the wall with masking tape in an x in the center. I have seen the up and down on both top and bottom of a light, but if you use the tape you can put it back if you screw up, as well as see your change.
find a wall at night bring a flashlight and a screw driver......trial and error
I guess i was asking if anyone knew which screw made what adjustment,,,,
I didnt want to start twiking on the other one by mistake........
but thanks for answering
cookie's right - most people do this so seldom that we have to "re-learn" which one does what by trial and error. If you point the car at a shady wall (or do this at night), mark the bright spot from your headlights on that wall with some tape, you can then see how each spot moves in response to each adjustment and figure out where you want the re-aim point to be.
