May 10, 200619 yr sat at aamco for 2 weeks while they rounded up everything to fix the tranny.. new valve body, torque converter, shift solinoid, planetary gears, forward clutch plate, rear clutch plate, clutches, bands, on down the list.. everything was replaced... shes home with about 75 miles on it so far, is like brand new.. couldn't have asked for a better job from anyone..
May 10, 200619 yr Hope it turns out well for you, we just replaced one in ours from the junk yard, seems fine now but I guess time will tell. sat at aamco for 2 weeks while they rounded up everything to fix the tranny.. new valve body, torque converter, shift solinoid, planetary gears, forward clutch plate, rear clutch plate, clutches, bands, on down the list.. everything was replaced... shes home with about 75 miles on it so far, is like brand new.. couldn't have asked for a better job from anyone..
