May 12, 200619 yr I thought I would pass on to y'all a PN for thin headgaskets for the EJ22. I just picked up a set I had made through Cometic gasket in a thickness of .027" as opposed to the OEM .040". If you're looking for good gaskets and want to bump the CR a bit too, these'll fit the bill. PN: C4262-040........EJ22E SOHC 16V, 98mm MLS .040" (stock) PN: C4262-027........EJ22E SOHC 16V, 98mm MLS .027" (thin) These should run about $90 for the set. Enjoy!
May 13, 200619 yr What does it bump the compression ratio up to? Would i have to run a higher test gas?
May 13, 200619 yr Other thing to consider, you may have made the engine an interference engine now....
May 13, 200619 yr Author I don't know how much the CR is effected yet. It shouldn't require higher octane. Post 97 EJ22s are already interference. Jay Storm
