June 7, 200619 yr I have installed a weber 44 idf on my ea82, eliminated all smog crap, and computer Bought a distributor from a carb'd ea81. I can't get any spark thru the distributor...replaced the ignition module... still no spark...ignition module only has two wires...not sure what the deal is... dh84 distributor...DO I NEED THE COMPUTER FOR THIS DIST. TO WORK? DOES ANYONE HAVE A POINTS/CONDENSOR DISTRIBUTOR THAT WORKS? Thanks
June 7, 200619 yr on the EA-82 the distribuiter is ECU controled. and is more of a cam sensor than anything... look around, see if you can retrofit points into something to make it work... -=Suberdave=- http://www.suberdave.com
June 8, 200619 yr No - EA81 disty should work - provided you change the drive gear to fit the EA82. GD
