June 29, 200619 yr Ok, so after finding out the hard way that neither Autozone nor Schmucks knows the difference between a mechanical steering pump for an XT and a cybrid pump for an XT6, I'm coming to the conclusion that I seriously do not have any choice but to rebuild the existing pump. I've called the local Soob dealership a couple times to try to get info and one guy said he can order it and quoted me a price, but when I called back to order it, the other guy couldn't find the parts. can anyone give me part numbers for both the motor brushes for the cybrid steering pump and the seal/o-ring kit for the pump?
June 29, 200619 yr part number for the brushes: 31266GA340 and they are still available. never heard of anyone buying the o-ring/seal kit. i'd match some up or measure. generic brushes can be found too, any automotive electrical shop can have a look at the old ones and the end cap of the pump (that houses the brushes) and get you a set for a couple dollars.
June 29, 200619 yr Author part number for the brushes: 31266GA340 and they are still available. never heard of anyone buying the o-ring/seal kit. i'd match some up or measure. generic brushes can be found too, any automotive electrical shop can have a look at the old ones and the end cap of the pump (that houses the brushes) and get you a set for a couple dollars. The o-ring kit is something that Mike @ Smart Service suggested... I trust his judgement, besides the fact that in addition to not functioning, I know the pump is also leaking (out the hose side, right onto the cat) thanks for the p/n on the brushes, that's a good start.
