Service Bulletin Question
Does anyone have the text of bulletin 15-117-06, Keyless Remote Transmitter Modification?
The information on http://techinfo.subaru.com indicates this bulletin is to correct unintended actuation issues with the keyless remote. I am interested to know what they consider "unintended actuation" and the nature of the repair.
I have found that the remote on my 2005 Legacy will unlock the doors with only a vary light touch of the unlock button. I would like something like a one second delay (similar to the trunk). If this is the sort of thing the bulletin discusses, then I will have the dealer do it the next time I have my oil changed.
TIA,
mikkl
an example would be,
you have the key fob in your pocket, and it sets off your panic alarm
or unlocks the doors without you "touching" the fob itself...
Thanks Jamie--that is not what I am seeing. I simply have a twitchy switch.
Thanks again,
mikkl
anyone have this June 2006 bulletin -- or know what the local dealer ought to know about it?
Engine Cooling System Flush and Refill (1619.92kb) WWY-09
