July 18, 200619 yr The passenger side intake gasket on my 95 legacy GT failed after only 5K miles. When I took the manifold off the gasket looked squashed and had cracked in several places. Did I over torque the manifold? What is the correct torque? Do people use sealant or not? Suggestions? Thanks!
July 18, 200619 yr No sealant. Clean both surfaces thoroughly. About 15 ft. lbs. MAX. Emily http://www.ccrengines.com
July 18, 200619 yr Sounds right. Overtorquing those bolts is all too easy, use a good torque wrench on the new gaskets.
July 18, 200619 yr Author Thanks for the info. I guess I won't use the 3/4" impact gun this time and the 3 foot breaker bar is totally out of the question!
