camanojer Posted July 20, 2006 Share Posted July 20, 2006 What if anything is involed in changing a 1990 Legacy AWD automatic transmission with a transmission from a 1995 Impreza AWD automatic. Should I incur any problems or should everything interchange and work. Link to comment Share on other sites More sharing options...
Gnuman Posted July 21, 2006 Share Posted July 21, 2006 Biggest problem would be the final drive ratios. Get the rear diff from the donor car as well as the tranny. I'm not sure if the wiring on the plugs is the same, you should check the pinouts for both trannies Link to comment Share on other sites More sharing options...
