July 22, 200619 yr With Drum Brakes rear. I replaced the drums but not the shoes. The shoes looked OK the drums weren't bad either just a lot of external corrosion. Had a helper gently press the brakes and the shoes move OK. Replaced the front pads. The calipers seem fine and I was able to press the two pistons back using just my thumbs. The sliders slide fine. I still have a low brake pedal. Although the brakes work fine, the pedal goes down about half way before getting a bite. I backed the car up and pressed the brakes to activate the self-adjusters, didn't help. Is there a rod on the brake pedal leading to the master cylinder? Should this need adjustment? I didn't bleed the brakes but it is probably due for a flush. The power unit seems to be working fine. What else should I be checking for this? Thanks Much.
July 22, 200619 yr Author Bleed the brakes. This thing use dot 3 or 4? may as well do the whole flush deal. Thaks for the reply.
July 22, 200619 yr http://www.scoobymods.com/forums/showthread.php?t=182 The above is step by step and sequence for bleeding Subie brakes. Check the manual but I think there is fluid that is compatable with either.
