motojeff Posted July 29, 2006 Share Posted July 29, 2006 I am still trying to figure out what is wrong with my CC on my 2000 OBW. I do not hear any click of a relay when I move my steering column CC switch/Lever. Should I hear a relay? I can hear the relay in the CC module click when the dash button is activated. I have verified the brake switch continuity. If there is a relay for the column CC lever, where is it located? I cannot find a schematic showing me a location. Thanks, Jeff Link to comment Share on other sites More sharing options...
sea#3 Posted July 30, 2006 Share Posted July 30, 2006 I am still trying to figure out what is wrong with my CC on my 2000 OBW. I do not hear any click of a relay when I move my steering column CC switch/Lever. Should I hear a relay? I can hear the relay in the CC module click when the dash button is activated. I have verified the brake switch continuity. If there is a relay for the column CC lever, where is it located? I cannot find a schematic showing me a location. Thanks, Jeff This might help , you did not say if it was an auto or standard SEA#3 Link to comment Share on other sites More sharing options...
motojeff Posted July 30, 2006 Author Share Posted July 30, 2006 This might help , you did not say if it was an auto or standard SEA#3 Thanks, I will look for an inhibitor switch. It's an Automatic Transmission. All brake lights are working, my speedo works fine, and I checked the CC fuse on the inside Fuse Box with a multimeter to make sure it was good. I took the column CC lever out and cleaned it and did not see anything out of whack. Thanks for the reply SEA#3. Jeff Link to comment Share on other sites More sharing options...
mattocs Posted July 31, 2006 Share Posted July 31, 2006 Funny story... When my CC went bad in my Outback, I got a new CC kit and replaced EVERYTHING. It ended up being the the little rubber thing that hits the switch when the clutch is depressed. Might want to check out the rubber thing with the brake switch. Good luck! Link to comment Share on other sites More sharing options...
motojeff Posted July 31, 2006 Author Share Posted July 31, 2006 Is this the Inhibitor switch for the CC? Link to comment Share on other sites More sharing options...
motojeff Posted August 1, 2006 Author Share Posted August 1, 2006 Is this the Inhibitor switch for the CC? Nipper.. is this the inhibitor switch? I figured you would know if anyone would. Link to comment Share on other sites More sharing options...
