Rip Posted August 2, 2006 Share Posted August 2, 2006 Hello im new here so i hope im in the right spot. I have a 1986 subaru wagon with a carb motor and i have really nice turbo fuel injected motor i would like to put in does anybody know exactly what i need to change to do this swap. I was going to swap intakes but one is a single port and the other is dual port. Can i just change the harness and comp? or is there more? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 4, 2006 Share Posted August 4, 2006 Buy a turbo car. The swap is not worth the trouble. Among other things, you would have to swap: Engine cross member (to clear the turbo exhaust) Exhaust manifold - at least back to the mid-pipe Entire fuel system - pump and lines as carb system is not designed for 40 psi Engine computer, and all associated wireing (really need a donor car's wireing harness for all that) All that for like 20 HP (under boost) is not worth the effort. Swap an EJ22 in there. Less work, more HP (135 - no turbo), and donor legacy's are getting aweful cheap anymore. Add to that the EA82T's are just not that reliable - really a troublesome engine compared to the EJ22. GD Quote Link to comment Share on other sites More sharing options...
