August 12, 200619 yr Tried a search, came up with nada- Did anything actually use the 32/36 Weber, or are gaskets available from Napa? If not, anybody got a junk gasket they can send me, or scan and e-mail? I need one for a pattern.
August 12, 200619 yr The Holley-Weber 5200 was used on a lot of early Ford stuff - Pinto's and the like. It's a DVF weber licensed by Holley, but if you are just concered with the base pattern it's identical to the DGV weber as far as fitment. A lot of folks use them on the EA82 since the linkage is reversed - same adaptor plate works for both. Or you can hit up any VW shop and they can sell you a gasket for either one. GD
August 12, 200619 yr The Holley-Weber 5200 was used on a lot of early Ford stuff - Pinto's and the like... 71 through 74-ish Pintos and Capris with 2.0L 4-cyl, and possibly Capris with 2.6L V6. Probably later years on these and Mustang-IIs. But 71 Capri for sure. (Brother had one. I actually liked the H-W 5200, and did a lot of tuning on it.)
