August 22, 200619 yr I have discovered a little seepage around the rubber seal where the plastic brake fluid resevoir connects to the master cylinder. Does anyone know if these seals are available alone. Or do I need to replace or rebuild the master cylinder. It looks like the resevoir just "pops" into the master cylinder. I only noticed one phillips screw on the side. Does anyone have any experience with this. Thanks. BCO
