OBD II EJ22 Swap?
I have a GenII EJ22 out of a 95 Legacy sitting in my yard in which I would like to use as a swap into my ea81 wagon. I have not seen to many posts about how much harder swapping a OBD II engine would be. Anything I should be worried about? Or should I just dump the OBDII and get a OBDI?
Thanks
Jeremy
95 should still be OBDI......unless it was built very late in the year and somehow was made with OBDII. 96+ is OBDII for sure.
The wiring that came with the motor should still be able to be fitted to your car, no?
Jay
go with the obdII if you have it. I am running a 96 in mine and if you have the two sets of factory manuals the conversion isn't bad.
