duty solenoid c
Hi all,
Can you replace the duty solenoid c without removing the tranny tail housing? I am getting a code 24 with is the solenoid. Tomorrow I am going to get under the car & check the solenoid. I would like to know so I can buy the gasket while at the dealer getting the solenoid. Thanks.
nope, you have to remove the rear extension housing to get at the duty c solenoid.
Make sure you test the wiring to the solenoid to make sure that's not the problem.
What symptoms are you having, other then light being on & that code stored.
Josh,
Bad torque bind. Installing the fuse helps a little but when I check the duty solenoid I get a open. From what I can find that will put the AWD into 50/50 regardless of the fuse. I have already checked tires & changed all the fluids. Anything I might have overlooked? Thanks.
I will check fro continuity from TCU harness to the soenoid if I can find the connector at the tranny. Also, is there anyway to know if the clutch packs are bad while I have the extension housing off?
