September 12, 200619 yr I know this question has poped up in the past and I did do a search but never found and truly solid answers. Can anyone tell me the torque and the tightening sequence for the camshaft cap bolts on a 1997 2.5 OBW. Thanks.
September 14, 200619 yr Here is the relevant info from the FSM. Hope it Helps... Matt 1997camshaft.pdf
September 15, 200619 yr Author Matt, thanks so much for the info. I read some other posts that mention there was a missprint on the torque in the FSM for the cam cap bolts, do you know if the spec listed in your reference is updated? Thanks, Sam Here is the relevant info from the FSM. Hope it Helps... Matt
September 15, 200619 yr I am not sure if the specs are updated or not, maybe someone else knows the torque value. matt
