September 21, 200619 yr Does anyone know why I would get a noise from my steering column that sounds like a power steering sensor or electric motor when my clutch is pressed in, but not when I let it out? Logically I can not figure out how these two are connected. This is an 87 GL 4x4
September 21, 200619 yr Or the clutch cable boot has been disloged from the fire wall, my 85 hatch does that. when the clutch is puched in, the cable flexes and it can let in engine noise. Check the boot.
September 22, 200619 yr Author I dont think it is the throwout bearing, as I dont hear the same noise outside the vehicle... I will definately check the boot, tha may be it..
