teppichkopf Posted September 28, 2006 Share Posted September 28, 2006 '96 Legacy OBW EJ22 5sp I'm finally getting motivated to fix this MAF hesitation problem. I dont' want to deal with is when there's snow in the passes (ski season). But just this week I've also gotten a little whine (sounds like a bird) with the chugs from 2k-3k rpm. I certainly need to finish the full precedure: pcv, wires, front o2 sensor, and MAF. But about the whine: must be vaccum? I also get a high pitched whine above 5.5k rpm. (not that I'm there much.) I've looked high and low and cannot find a vacuum leak. Neither brake cleaner or starter fluid make a change in rpms when sprayed around the engine compartmant. I can't even find the infamous hose under the air filter box. I just hope a new used MAF clears up all the issues.Should I buy new? Or can I trust a used one? If anybody has a working MAF (AA160F) let me know. Link to comment Share on other sites More sharing options...
seanski06 Posted September 28, 2006 Share Posted September 28, 2006 how do u know when its time to replace it? other than a cell Link to comment Share on other sites More sharing options...
