October 30, 200619 yr 3 valve EFI justy. Need any motor parts? I need to know by 7 AM tomorrow to spray SAVE on the windshield.
October 31, 200619 yr 3 valve EFI justy. Need any motor parts? I need to know by 7 AM tomorrow to spray SAVE on the windshield. Hi, What I need if it has the parts: #1-passenger side rear view mirror #2-fuel injectors. a spare set would be good. new is expensiive. #3-the short block if it's good #4-both tail lights if good #5-both headlights if good. leakers ok if they're intact. #6-inside rearview mirror and the retaining plastic screw #7-exaust manifold and cat Probably more if it isn't crushed and priced right. Doug
October 31, 200619 yr i need a justy hub. a friend of mine has one with a striped hub (right front i beleave, but sould be the same as the left)... let me know what you can do... -=Suberdave=- http://www.suberdave.com
October 31, 200619 yr Author All motor parts are there. Manifold is there, cat isn't. Will tag for saveing. 2 justy's there, one EFI, one carb. both 2wd. Will tag EFI one. Carb is 5spd. Didn't check EFI one for tranny style. Prices are cheap.
October 31, 200619 yr All motor parts are there. Manifold is there, cat isn't. Will tag for saveing. 2 justy's there, one EFI, one carb. both 2wd. Will tag EFI one. Carb is 5spd. Didn't check EFI one for tranny style. Prices are cheap. I have a friend who needs a shortblock for an '89 2 wheel drive 5 speed, carbed Justy. Chances of it not having the "low oil pressure problem"...humm. I'm going to sleep.lol Will check in tomorrow. Doug
October 31, 200619 yr Author Sending a shortblock to Ohio might be a tad expensive. I'll tag the EFI one tomorrow. The shortblock out of it should be the same.
