fnlyfnd Posted November 20, 2006 Share Posted November 20, 2006 Well after running mt90 with minimal problems, I changed it because its not good for the diff. Now I am running uncle scottys cocktail but I get a faint whine when acclelerating (most of the time), and 2nd gear is a PIA to get into. Now I am going to change it again, prolly setright's suggestion of valvoline synpower. what do u guys think?? setright do you use this straight? how is it in the cold? Quote Link to comment Share on other sites More sharing options...
Smpol19 Posted November 20, 2006 Share Posted November 20, 2006 I'm usually a big synthetic fan, but after 2 years of different mixes including Mobil 1 75W90 and Red Line 75W90NS and a few mixes. I’ve just gone with dyno 75w90 and it works well, is dirt cheap, I still get a slight grind going into 3rd if I shift too fast, but I did with everything else too. This is probably the only case I would say go with a decent 75w90 dyno. Quote Link to comment Share on other sites More sharing options...
Setright Posted November 20, 2006 Share Posted November 20, 2006 In the cold it's a little bit "baulky", but only the first mile or two, then it smoothes out. Once warm, the gearstick moves around the gate with ease You really should try it. I was near giving up on my gearbox until a Danish rally driver suggested I try Synpower...haven't looked back since. Quote Link to comment Share on other sites More sharing options...
