92 legacy hill assist problem.
i recently had my clutch replaced with a new OEM clutch kit. everything seemed fine until i tried to pull out on a hill. the hill assist worked too well as i was unable to pull out, buck up or anything else for that matter. can anyone tell me how to adjust the hill assist to work properly or can this feature be overidden completly ? tia.
There are two cables attached to the clutch fork. One goes through the firewall to the clutch pedal, and the other one goes over to the hill holder valve which is mounted below the brake master cylinder. You will need to loosen that cable.
Keith
thank you sooooo much Keith. i appreciate your response :banana:
