WRXenstein
I have :
A) a rolled, cosmetically destroyed 1996 clubspec Rallye WRX (ie organ/parts donor)
B) an 1981 L series wagon
I want :
Everything cool and worthwhile from A) into B)
Where does the WRX stop and the GL wagon begin ?
Just the driveline ? Or axle to axle and driveline ?
I'm wondering if there are any recognised pitfalls to avoid.
Any clues or nuggets of hardwon wisdom will be much appreciated. Once I start this project, I'll do my best to keep a journal in the hope that I can help everyone else with other equally fun conversions. :)
cheers in anticipation fellas !
Beer supplied to anyone who comes to help :D
Engine swap w/stock EA tranny is an option however the EJ motor would probably kill the EA tranny.
There is a thread here of someone was combining a Outback Sport w/a BRAT
http://www.ultimatesubaru.org/forum/showthread.php?t=34445&highlight=brat
It's been in the works for almost two years now.
The drivetrain might go in a little easier if you make a subframe that bolts to the EA mounting points and then bolt the EJ parts to the subframe.
I put a EA82 crossmember w/PS to my BRAT. I used the lift block as an adapter b/c the mounting holes for the two are different.
Good luck
BW
