Xt
I don't know much about XT's but I wanted to know if any of the AWD parts off of a 89' wagon can be swaped to a 87' XT to make it AWD?
yes, all the rear stuff will carry over, basically the entire rear end. the bolt holes may or may not be in place for the rear cross member and center carrier assembly of the driveshaft but they are easily drilled and tapped if necessary.
mr. radon documented converting a FWD XT6 into AWD over at xt6.net, might want to check his thread out. if you're not a member, give me a heads up and i'll make sure you join smoothly.
I'm not a member over there but I guess I should join, I am about to buy an 87' XT. Do you have a link to that write up?
