January 21, 200719 yr Dorothy is leaking out of the p/s axle stub on the trans. What's involved in fixing this? Its a pushbutton 4wd turbo trans.
January 22, 200719 yr there is an O ring and a seal. you need to mark the location of the retainer and then spin it out(can be tricky) then replace and lube o ring and seal AFTER removing retainer. seals cannot be changed with out pulling the retainer out. axle has to be removed obviously.
