pinnhedd Posted January 31, 2007 Share Posted January 31, 2007 Cooling Fan Rationality Check Malfunction What does this mean? I have tried to search online for it...Does anyone have any ideas for me? I can't find any info on it really. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted February 1, 2007 Share Posted February 1, 2007 Hello, P0xxx is a generic ODBII code. At least for '00obw (closest service manual i have listing that code) that means A/T DTC P0483 - COOLING FAN FUNCTION PROBLEM DTC DETECTING CONDITION: Two consecutive driving cycles with fault TROUBLE SYMPTOM: Occurrence of noise; Overheating Do the cooling fans seem to turn on at all? Do the funs cycle on and off if th A/C is on? Does the temp gauge seem to get any higher than the middle or so? Quote Link to comment Share on other sites More sharing options...
pinnhedd Posted February 1, 2007 Author Share Posted February 1, 2007 I have a '98 Forester. Temp gauge does not go more than in the middle...once it's all heated up it stays in the same spot. Has not overheated since I have owned it. Only other info I got was from Mitchell on Demand at work...basically saying that it could even be caused by parking next to another vehicle while at idle...strange. Hello, P0xxx is a generic ODBII code. At least for '00obw (closest service manual i have listing that code) that means A/T DTC P0483 - COOLING FAN FUNCTION PROBLEM DTC DETECTING CONDITION: Two consecutive driving cycles with fault TROUBLE SYMPTOM: Occurrence of noise; Overheating Do the cooling fans seem to turn on at all? Do the funs cycle on and off if th A/C is on? Does the temp gauge seem to get any higher than the middle or so? Quote Link to comment Share on other sites More sharing options...
ferret Posted February 1, 2007 Share Posted February 1, 2007 It means the ECU turned both fans on and expected the coolant temp to decrease by X degrees after a predetermined time and it did not. Be certain both fans are operational, The radiator is clear for air to pass thru, nothing blocking airflow, could be a clogged radiator. could be low on coolant. But now you get the idea...... ECU tried to cool the engine and couldn't. Quote Link to comment Share on other sites More sharing options...
