_Aramchek_ Posted February 4, 2007 Share Posted February 4, 2007 I have two 2.2's,one is my outbacks original,it has red fuel injectors. The replacement motor has gray fuel injectors,is there any signifigant difference? What is the difference if any? Would it be worth switching the red ones on to the motor in my car? Link to comment Share on other sites More sharing options...
_Aramchek_ Posted February 5, 2007 Author Share Posted February 5, 2007 No one knows? Link to comment Share on other sites More sharing options...
86ruguy Posted February 5, 2007 Share Posted February 5, 2007 the only thing i know is that the red ones are late 91 and up, gray ones are 90 to late 91, both are for automatics. i'm not sure if they will work with the other ones MAF Link to comment Share on other sites More sharing options...
Legacy777 Posted February 5, 2007 Share Posted February 5, 2007 There are slight differences in the nozzle type, which affects fuel flow for a given pulse length. You need to use the injectors that match up with the ECU you are using. If your current motor/ecu uses the red injectors, you should pull the fuel rails off and swap them over to the new motor. The other injectors will run, but I experienced very poor mileage and loss of power, which I contributed to the fact I was running richer then I should have been. Link to comment Share on other sites More sharing options...
_Aramchek_ Posted February 5, 2007 Author Share Posted February 5, 2007 There are slight differences in the nozzle type, which affects fuel flow for a given pulse length. You need to use the injectors that match up with the ECU you are using. If your current motor/ecu uses the red injectors, you should pull the fuel rails off and swap them over to the new motor. The other injectors will run, but I experienced very poor mileage and loss of power, which I contributed to the fact I was running richer then I should have been. Thanks,that's kind of what I suspected,but I wasn't going to go through teh effort if there was no real difference. That's probably what's responsible for my occasional sputtering problem. Link to comment Share on other sites More sharing options...
