code 34
Replace the solenoid with a 68 ohm (or anywhere around that) resistor and see if the light stays off. If it does, you still have a bad solenoid. If it still comes on, you have either a wiring problem or a bad ECU, most likely a wiring problem. The connector could be your problem.
