Auto Trans Pan Gasket
Does The 2002 Outback Use A Pan Gasket Or Do You Just Use Rtv To Form A Gasket. Mine Leaks And I Need To Replace.
From the factory, the pan would be sealed with RTV. Has your powertrain warranty expired?
make sure it's the pan leaking, other leaks can make the pan mating area wet and look like it's the pan but it's not.
yes
IT only leaks at a cold start up. I observed a drip coming from the gasket right near the external trans filter. was told that it might be the rear extension housung , but that does'nt sound right.
