March 11, 200719 yr I wired in my EJ harness to various connectors on the EA dash-tach,charge light,CEL,,ignition positive off ignition switch. my question is I have no indicator lights at startup no CEL,no charge,no oil,no nothing in the instrument brezel.When I tried to see if the motor would crank when the battery was just hooked to the charger.Anyway when I tried to see if it would crank I heard this clicking from behind the dash.Also when I tried it I didn't have the ECU memory wire hooked up or the wires from the alternator to the battery.Could that be a cause of the problem?I'll try connecting the memory wire to something tommarow.that and my open fuel line pumped some fuel on the engine(carbie pump still attached:dead: ) need to wire in FI fuel pump and FI lines.
March 11, 200719 yr most of the lights and such only get a ground from the 2.2l ECU. the power comes from the car. have you checked that you have power? check fusable links... -=Suberdave=- http://www.suberdave.com
March 11, 200719 yr Author well I did forget to wire the ECU ground and memory wire in:dead: I feel stupid.I guess I just wanted to see if my wiring was correct...
