Where does the XT6 blue power steering recall wire bolt to?
there's a single blue wire that's not part of the wiring harness (because it's part of the power steering recall) that bolts to the back of the power steering pump. looking from the drivers side of the engine bay you can see the back of the pump. this wire is either connected to the negative terminal at the 5 oclock position or the stud at 3 oclock. both of these positions have other wires connected to them, but this single wire will be exposed and running along the length of the bottom edge of the windshield, not covered or hidden in the harness.
anyone with an XT6 want to help me out here?
all it requires is looking under your hood.
are you sure it's the "loose" wire that's the lone wire connected into the plug by the drivers side strut tower? it's connected to the "postitive" terminal at the 10 oclock position? that sounds odd, got a picture you can email me?
grossgary at the yahoo place.
