May 11, 200718 yr So yesterday i replaced my eaten spark plug cables. It is hard to get them here but at a garage nearby they had a crashed 95 legacy (side crashed). (In holland products are not on the shelf only in central warehouse, so prefered a used part). So took the cables 4 for $30 did not seem to bad. But the car also had cruise control, which i dont have. The engine was the same but will this system work in my 91 legacy. It will fit in the same locations on the firewall but, will the computer fit in my car and work with the ECU?
May 14, 200718 yr Hmm....I'm not sure if they'll work. To be honest, if you've already bought the parts, I'd just hook it up and see if it works.
May 15, 200718 yr I think they're cable driven cruise control, not vacuum controlled? From memory of installation in 1995 LX Liberty from GX was easy but from 95 to 91, I cannot be sure if there will be wiring differences, I think they will be. Cheers AP
May 25, 200718 yr Author I dont have the parts yet, they are in a crashed car at a dealer (no subaru goes to a junckjard here). The engine is the same (layout ej20) and there is a cable going from the firewall (out of a black canister) to the throttle. This part will fit easy since its the same as with the '91. But will the control module fit in the electric system?
May 25, 200718 yr That I couldn't say. The cruise control module for the 91 is on the right side of the glove box....(for a left hand drive car) Do you currently have cruise now? Is something wrong with yours, is that why you want to swap it out?
