code P0261 ???
this is for low voltage to injector 1... Anyone know what causes this? where to look for the culprit? fixes?
This vehicle (99 OBW) has NEVER given me any problems... love this machine.
Any help/ideas/thoughts appreciated.
Later,
Peter
Check for a bad connection to the injector. The wire to the injector should be brown and if you have a 2.2L engine it goes to pin 4 on the ECU and if you have a 2.5L it goes to pin 26.
It was more exciting than that! a mouse had chewed through the wire!!!!
I do appreciate the response. the "mechanic" was talking about replacing the entire Brain as it was the likely culprit... maybe a relay... if I was lucky.
While we were looking under the hood I saw a wire stricking out through the sheilding.... & asked if that may be the problem...
Thanks for your reply, Cougar, since I know this board will offer more help than "guess work" mechanics.
Later,
Peter
I was about to say look at your wiring for frayed or chewed through parts int he insulation.
We have plenty of pack rats here and they tend to make thier homes in the engine bay when left sitting, they just love to chew through wiring.
